Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Gigmods Module Mods
1087 Question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="okstrat" data-source="post: 72178" data-attributes="member: 157"><p>Never told anyone that they added noise. I did do tests to see if using the cage had any purpose other than keeping your hands off the hot tubes until you could find a screwdriver. It doesn't. I figured it MIGHT cut down on noise a little, but it made no difference. Modules were just as noisy without the cage as with the cage.</p><p></p><p>Since the cages don't really serve a purpose other than to make someone wait a bit before changing tubes, I leave them off when it could interfere with wiring or be a pain. I did get a module back once that had a wire that was grounding out on the cage, so more often than not I just remove the cage.</p><p></p><p>Pete</p></blockquote><p></p>
[QUOTE="okstrat, post: 72178, member: 157"] Never told anyone that they added noise. I did do tests to see if using the cage had any purpose other than keeping your hands off the hot tubes until you could find a screwdriver. It doesn't. I figured it MIGHT cut down on noise a little, but it made no difference. Modules were just as noisy without the cage as with the cage. Since the cages don't really serve a purpose other than to make someone wait a bit before changing tubes, I leave them off when it could interfere with wiring or be a pain. I did get a module back once that had a wire that was grounding out on the cage, so more often than not I just remove the cage. Pete [/QUOTE]
Verification
Post reply
Modular Amps
Gigmods Module Mods
1087 Question
