Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Gigmods Module Mods
Amp emergency kit
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="okstrat" data-source="post: 37916" data-attributes="member: 157"><p>You would use the meter to test for continuity like you would a fuse - most digitals have a setting that will beep if the probes make contact with each other. You would touch the grounded parts of each end of the cable and see if you got a beep or continuity (this is good) and then check the tips of the cables for the same thing. Cable would be bad if you didn't get continuity between end tips or grounded parts, or if you had continuity between ground and tip. That would mean your cable was shorted out.</p><p></p><p>Pete</p></blockquote><p></p>
[QUOTE="okstrat, post: 37916, member: 157"] You would use the meter to test for continuity like you would a fuse - most digitals have a setting that will beep if the probes make contact with each other. You would touch the grounded parts of each end of the cable and see if you got a beep or continuity (this is good) and then check the tips of the cables for the same thing. Cable would be bad if you didn't get continuity between end tips or grounded parts, or if you had continuity between ground and tip. That would mean your cable was shorted out. Pete [/QUOTE]
Verification
Post reply
Modular Amps
Gigmods Module Mods
Amp emergency kit
