Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Any difference b/w stock Randall/Egnater mods and Synergy?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="AdInfinitum" data-source="post: 158575" data-attributes="member: 443"><p>I have an RM22 but I put it behind my monitor thinking I wouldn't change modules often. The OX is a box that is both a load and attenuator. Plug your guitar into an amp, take the speaker out to the OX and with OX software, it has virtual cabs and pics for recording your amp to the DAW or FOH or back to your amp speaker. There are five levels of attenuation and a headphone out. Some complain about the attenuator due to only five levels.</p><p></p><p>I could run the Syn-2 {Sweetwater doesn't have Syn-1's in stock so I switch to a Synth-2 instead [which probably was the better choice to begin with) into the Tewo-Notes CAB since that has a power amp sim or probably plenty of other software power amp sims. I probably could run that into the Axe and turn off Preamp modeling then turn off the CAB IR and then run it into the OX. Hmmmm</p><p></p><p>Thanks, your response triggered some interesting possibilities. I'm going to post that idea on the Axe forum.</p></blockquote><p></p>
[QUOTE="AdInfinitum, post: 158575, member: 443"] I have an RM22 but I put it behind my monitor thinking I wouldn't change modules often. The OX is a box that is both a load and attenuator. Plug your guitar into an amp, take the speaker out to the OX and with OX software, it has virtual cabs and pics for recording your amp to the DAW or FOH or back to your amp speaker. There are five levels of attenuation and a headphone out. Some complain about the attenuator due to only five levels. I could run the Syn-2 {Sweetwater doesn't have Syn-1's in stock so I switch to a Synth-2 instead [which probably was the better choice to begin with) into the Tewo-Notes CAB since that has a power amp sim or probably plenty of other software power amp sims. I probably could run that into the Axe and turn off Preamp modeling then turn off the CAB IR and then run it into the OX. Hmmmm Thanks, your response triggered some interesting possibilities. I'm going to post that idea on the Axe forum. [/QUOTE]
Verification
Post reply
Modular Amps
