Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Change Fans in Syn 5050
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="btownninja" data-source="post: 161963" data-attributes="member: 4105"><p>I'm pretty sure the fans are at least two speed. There's a low speed mode for idle/low load and a higher speed mode when it starts to get hot. Noctua also doesn't sell any 2 pin fans that I'm aware of, but it's possible you can use a 3/4 pin fan in a '2 pin mode' if that exists. it might just control speed with different amperage. </p><p></p><p>Either way, I'm going to try and attempt this at some point. I'll try and remember to update back with my experience. It will probably be a while as I moved and don't have a workbench yet</p></blockquote><p></p>
[QUOTE="btownninja, post: 161963, member: 4105"] I'm pretty sure the fans are at least two speed. There's a low speed mode for idle/low load and a higher speed mode when it starts to get hot. Noctua also doesn't sell any 2 pin fans that I'm aware of, but it's possible you can use a 3/4 pin fan in a '2 pin mode' if that exists. it might just control speed with different amperage. Either way, I'm going to try and attempt this at some point. I'll try and remember to update back with my experience. It will probably be a while as I moved and don't have a workbench yet [/QUOTE]
Verification
Post reply
Modular Amps
