Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Connecting 2 X SYN2
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MarcoR" data-source="post: 155364" data-attributes="member: 961"><p>If you don't need to worry about a host amp, it should be easy to connect. For the FX8, you would probably need to assign a different midi channel to each SYN2 so you could control one with PC and the other with CC as the FX8 only allows one each per scene.</p></blockquote><p></p>
[QUOTE="MarcoR, post: 155364, member: 961"] If you don't need to worry about a host amp, it should be easy to connect. For the FX8, you would probably need to assign a different midi channel to each SYN2 so you could control one with PC and the other with CC as the FX8 only allows one each per scene. [/QUOTE]
Verification
Post reply
Modular Amps
Connecting 2 X SYN2
