Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Rigs & Tones
Decimator Prorack G Stereo Version?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Totenkampf" data-source="post: 127613" data-attributes="member: 3285"><p>i finally found a good deal on one, new in box for 225 shipped. sometimes it pays to look at CL right outside your area!</p><p></p><p>i have it in the serial fx loop of the preamp so fx send > BBE > ISP > fx return. I then have the delay / reverb unit in the parallel loop of the same preamp since it inserts downstream of the serial loop. seems to be working out and is similar to what audiomidijace is doing only he has his nova delay in the serial behind the ISP since he is using the reverb tanks of his combos in the parallel loop.</p></blockquote><p></p>
[QUOTE="Totenkampf, post: 127613, member: 3285"] i finally found a good deal on one, new in box for 225 shipped. sometimes it pays to look at CL right outside your area! i have it in the serial fx loop of the preamp so fx send > BBE > ISP > fx return. I then have the delay / reverb unit in the parallel loop of the same preamp since it inserts downstream of the serial loop. seems to be working out and is similar to what audiomidijace is doing only he has his nova delay in the serial behind the ISP since he is using the reverb tanks of his combos in the parallel loop. [/QUOTE]
Verification
Post reply
Modular Amps
Rigs & Tones
