Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
EGNATER verb quest
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MarcoR" data-source="post: 16306" data-attributes="member: 961"><p>Just call the Amp lounge. I talked to Frank about it and he explained that it was something that the average person could easily install. I believe he said it was about $200. </p><p></p><p>Basically, you can mount it in the back of the amp; just a few screws. It uses the parallel effects loop as has been stated. I?m sure you could use a rack delay in front of it as long as the delay unit has an input and output level adjustment. </p><p></p><p>I?m sure its sounds great as everything Egnater does but you might want to also consider something like a Boss RV-5 (I realize Boss is not nearly a sexy). You could Velcro it right in the back of the amp and run it in the parallel loop the same way.</p></blockquote><p></p>
[QUOTE="MarcoR, post: 16306, member: 961"] Just call the Amp lounge. I talked to Frank about it and he explained that it was something that the average person could easily install. I believe he said it was about $200. Basically, you can mount it in the back of the amp; just a few screws. It uses the parallel effects loop as has been stated. I?m sure you could use a rack delay in front of it as long as the delay unit has an input and output level adjustment. I?m sure its sounds great as everything Egnater does but you might want to also consider something like a Boss RV-5 (I realize Boss is not nearly a sexy). You could Velcro it right in the back of the amp and run it in the parallel loop the same way. [/QUOTE]
Verification
Post reply
Modular Amps
EGNATER verb quest
