Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
first position tube preamp
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Viet_Hetzer" data-source="post: 3910" data-attributes="member: 235"><p>Amp: B-52 AT-212</p><p></p><p>I don't know which preamp tube is the "first" preamp tube. Obviously I have a 50/50 chance of getting it but I'd like to get it on the first try so I don't need to wait for the amp to cool down again. When looking through the back of the amp, I see four big tubes (the 6l6's), then 6 little tubes (preamp tubes) to the right. Then to the right of the preamp tubes I see two tubes inside a metal barrier. Those must be the effects loop and reverb tube.</p><p></p><p>I would expect some sort of labeling system, like "PREAMP TUBE 1." or "POWER AMP TUBE 1." But nope. And I can't find any diagrams for my amp.</p><p></p><p>Which preamp tube is usually the first preamp tube in a amp set up like mine?</p></blockquote><p></p>
[QUOTE="Viet_Hetzer, post: 3910, member: 235"] Amp: B-52 AT-212 I don't know which preamp tube is the "first" preamp tube. Obviously I have a 50/50 chance of getting it but I'd like to get it on the first try so I don't need to wait for the amp to cool down again. When looking through the back of the amp, I see four big tubes (the 6l6's), then 6 little tubes (preamp tubes) to the right. Then to the right of the preamp tubes I see two tubes inside a metal barrier. Those must be the effects loop and reverb tube. I would expect some sort of labeling system, like "PREAMP TUBE 1." or "POWER AMP TUBE 1." But nope. And I can't find any diagrams for my amp. Which preamp tube is usually the first preamp tube in a amp set up like mine? [/QUOTE]
Verification
Post reply
Off Topic
