Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Jaded Faith Mods
Gain Structure
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Jaded Faith" data-source="post: 125226" data-attributes="member: 1068"><p>I'll start by referencing the post I made a stick the other day here: <a href="http://mtsforum.grailtone.com/viewtopic.php?t=17471" target="_blank">http://mtsforum.grailtone.com/viewtopic.php?t=17471</a></p><p></p><p>Although I don't have any experience running your exact setup, it should not be much different than running into a dedicated power amp. The best advice I have is to try setting it up several different ways and see what responds best to your playing. My rule of thumb would be to keep the modules at least at noon or better. The decision to use the RM4 Master or RM50 Master to control overall level is in your hands, but do set the one you don't use around 11:00 to 1:00 for good feel and sensitivity.</p><p></p><p>Hope that helps!</p><p></p><p>Rob</p></blockquote><p></p>
[QUOTE="Jaded Faith, post: 125226, member: 1068"] I'll start by referencing the post I made a stick the other day here: [url]http://mtsforum.grailtone.com/viewtopic.php?t=17471[/url] Although I don't have any experience running your exact setup, it should not be much different than running into a dedicated power amp. The best advice I have is to try setting it up several different ways and see what responds best to your playing. My rule of thumb would be to keep the modules at least at noon or better. The decision to use the RM4 Master or RM50 Master to control overall level is in your hands, but do set the one you don't use around 11:00 to 1:00 for good feel and sensitivity. Hope that helps! Rob [/QUOTE]
Verification
Post reply
Modular Amps
Jaded Faith Mods
Gain Structure
