Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Gigmods Module Mods
Gigmod XTC no treble
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="DSY555" data-source="post: 159976" data-attributes="member: 4115"><p>I have this XTC module modded by Gigmods and the treble does not work. The push pull switch on the master of the module does nothing as well. The master volume does work. Not sure if i should be looking at the treble pot or the 2 caps its hooked to. I'm guessing the push pull is a treble boost? nothing looks burnt on the bottom of the board. Could the module work with a bad part in the tome stack? Thanks for suggestions!</p></blockquote><p></p>
[QUOTE="DSY555, post: 159976, member: 4115"] I have this XTC module modded by Gigmods and the treble does not work. The push pull switch on the master of the module does nothing as well. The master volume does work. Not sure if i should be looking at the treble pot or the 2 caps its hooked to. I'm guessing the push pull is a treble boost? nothing looks burnt on the bottom of the board. Could the module work with a bad part in the tome stack? Thanks for suggestions! [/QUOTE]
Verification
Post reply
Modular Amps
Gigmods Module Mods
