Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
I really don't understand MIDI. Will these work?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="HughJasol" data-source="post: 94804" data-attributes="member: 2137"><p>Yes - I didn't factor that in, but any phantom power requirements will obviously play into the MIDI chain equation; just make sure the voltages and pins are correct. The RM100 actually supplies power on BOTH pins 6 & 7 AND pins 1 & 3. But what bit me was the fact that the RM100 supplies AC voltage - my Rivera Headmaster MIDI footswitch (and I have to assume others as well) requires DC voltage; so I can't use the RM100's 9 VAC to power it. I even touched base with Bruce to see if he could modify this and get me 9-15V DC on these pins, but he said there's no where to tap from.</p></blockquote><p></p>
[QUOTE="HughJasol, post: 94804, member: 2137"] Yes - I didn't factor that in, but any phantom power requirements will obviously play into the MIDI chain equation; just make sure the voltages and pins are correct. The RM100 actually supplies power on BOTH pins 6 & 7 AND pins 1 & 3. But what bit me was the fact that the RM100 supplies AC voltage - my Rivera Headmaster MIDI footswitch (and I have to assume others as well) requires DC voltage; so I can't use the RM100's 9 VAC to power it. I even touched base with Bruce to see if he could modify this and get me 9-15V DC on these pins, but he said there's no where to tap from. [/QUOTE]
Verification
Post reply
Modular Amps
