Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
JMP-1: OD1.. what module?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="drunton" data-source="post: 39337" data-attributes="member: 93"><p>Try a Plexi module with a good pedal. I use the Barber Direct Drive. It's been a while since I played through the JMP1's OD1, but I definitely don't feel like I miss anything with the current setup.</p><p></p><p>Gain is at 11 o'clock, right on the edge of break up, add the Direct Drive and heaven.</p></blockquote><p></p>
[QUOTE="drunton, post: 39337, member: 93"] Try a Plexi module with a good pedal. I use the Barber Direct Drive. It's been a while since I played through the JMP1's OD1, but I definitely don't feel like I miss anything with the current setup. Gain is at 11 o'clock, right on the edge of break up, add the Direct Drive and heaven. [/QUOTE]
Verification
Post reply
Modular Amps
Modules
