Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
KH speakers
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="sepherus" data-source="post: 64349" data-attributes="member: 2354"><p>Just to clear some stuff up if you plug a single head into both sides of the cab in stereo be sure that the head is set to 4 ohms as two 8 ohm loads run in parallel becomes a total of 4 ohms. If you are running 2 heads into the same cab it would be each head set to 8 ohms.</p><p>As for the sound difference with 4 and 16 ohm settings: 16 ohms has a wider bandwidth giving higher highs and lower lows. For some reason it also tends to seem a bit quieter. </p><p>4 ohms is a more focused sound as it is tighter in the lows and highs. It also has a touch more volume.</p></blockquote><p></p>
[QUOTE="sepherus, post: 64349, member: 2354"] Just to clear some stuff up if you plug a single head into both sides of the cab in stereo be sure that the head is set to 4 ohms as two 8 ohm loads run in parallel becomes a total of 4 ohms. If you are running 2 heads into the same cab it would be each head set to 8 ohms. As for the sound difference with 4 and 16 ohm settings: 16 ohms has a wider bandwidth giving higher highs and lower lows. For some reason it also tends to seem a bit quieter. 4 ohms is a more focused sound as it is tighter in the lows and highs. It also has a touch more volume. [/QUOTE]
Verification
Post reply
Modular Amps
KH speakers
