Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
LB head failure
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="RD/Rich" data-source="post: 14943" data-attributes="member: 1005"><p>If you plug into the extension jack you won?t hear any sound. Because of the way the way the ?use first? jack is wired, the ?extension? jack isn?t activated unless the other jack is also plugged in. Bruce is really the best guy to explain the WHY. He was the guy (read ?incredible freakin? genius?) who designed the amp and I?m sure he has his reasons for not wiring the jacks in parallel.</p></blockquote><p></p>
[QUOTE="RD/Rich, post: 14943, member: 1005"] If you plug into the extension jack you won?t hear any sound. Because of the way the way the ?use first? jack is wired, the ?extension? jack isn?t activated unless the other jack is also plugged in. Bruce is really the best guy to explain the WHY. He was the guy (read ?incredible freakin? genius?) who designed the amp and I?m sure he has his reasons for not wiring the jacks in parallel. [/QUOTE]
Verification
Post reply
Modular Amps
LB head failure
