Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Line vs. instrument levels
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Johan" data-source="post: 162163" data-attributes="member: 4542"><p>I had the same question and found the answer in the Syn2 manual (number 11 in the rear panel segment). The "effects loop level switch" allows you to set the level of the effects loop jacks to either instrument (pedal, as they call it) or line level. The manual suggests to use the setting that sounds best. The "Inst in" jack is obviously instrument level and cannot be switched to line. To use the same FX loop pair on the Helix you would have to set it to instrument level. You can set each FX loop pair (1 thru 4) to either line or instrument level in "Global Settings" on the Helix. And you would have to set the Syn2's "effects loop level switch" to instrument. If you don't like using instrument level for both in and out you can use two separate loop pairs on the Helix. If you set loop pair 1 to instrument and connect the Helix's Send 1 to Syn2's "Inst In" and, set loop pair 2 to line level and connect the helix's return 2 to Syn2's "FX send" and, set the Syn2's "effects loop level switch" to Line level. Hope that helps. </p><p></p><p>- Johan</p></blockquote><p></p>
[QUOTE="Johan, post: 162163, member: 4542"] I had the same question and found the answer in the Syn2 manual (number 11 in the rear panel segment). The "effects loop level switch" allows you to set the level of the effects loop jacks to either instrument (pedal, as they call it) or line level. The manual suggests to use the setting that sounds best. The "Inst in" jack is obviously instrument level and cannot be switched to line. To use the same FX loop pair on the Helix you would have to set it to instrument level. You can set each FX loop pair (1 thru 4) to either line or instrument level in "Global Settings" on the Helix. And you would have to set the Syn2's "effects loop level switch" to instrument. If you don't like using instrument level for both in and out you can use two separate loop pairs on the Helix. If you set loop pair 1 to instrument and connect the Helix's Send 1 to Syn2's "Inst In" and, set loop pair 2 to line level and connect the helix's return 2 to Syn2's "FX send" and, set the Syn2's "effects loop level switch" to Line level. Hope that helps. - Johan [/QUOTE]
Verification
Post reply
Modular Amps
