Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Little shot of reality!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="goldwing68nv" data-source="post: 3019" data-attributes="member: 89"><p>i have a rack-mount pod pro unit.the original,not the xt version and i run it thru a tubeworks 1160 mosvalve s/s power amp.it's great for lower level jams(i.e. bedroom use),but once you start cranking it up,it starts to thin out & lose that spunk.i've tried the pod pro through various hi quality el34 & 6l6 tube amps,but it still has that heavy digital processing vibe & doesnt capture that 100% tube magic.that's why i ended up buying my rm50hb.this randall mts head fits the bill for the higher volumes & full crankin' where the pod pro just doesnt shine its best.so,it's a little of the best of both worlds depending on the environment that i'm in at that particular moment......also,i have a pod xt "kidney bean" unit that i bought used off ebay and specifically use this unit for "effects" only.the amp modeling can be turned off.i can say that i have good results using it as an effects unit only.it is very transparent & i do not notice it color the amp's tone at all...</p></blockquote><p></p>
[QUOTE="goldwing68nv, post: 3019, member: 89"] i have a rack-mount pod pro unit.the original,not the xt version and i run it thru a tubeworks 1160 mosvalve s/s power amp.it's great for lower level jams(i.e. bedroom use),but once you start cranking it up,it starts to thin out & lose that spunk.i've tried the pod pro through various hi quality el34 & 6l6 tube amps,but it still has that heavy digital processing vibe & doesnt capture that 100% tube magic.that's why i ended up buying my rm50hb.this randall mts head fits the bill for the higher volumes & full crankin' where the pod pro just doesnt shine its best.so,it's a little of the best of both worlds depending on the environment that i'm in at that particular moment......also,i have a pod xt "kidney bean" unit that i bought used off ebay and specifically use this unit for "effects" only.the amp modeling can be turned off.i can say that i have good results using it as an effects unit only.it is very transparent & i do not notice it color the amp's tone at all... [/QUOTE]
Verification
Post reply
Modular Amps
