Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Low Volume
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="j4q0" data-source="post: 155266" data-attributes="member: 3288"><p>When using the 5153 or the SYN5050 the signal path is the same for me:</p><p>Guitar > RM4 or SYN2 > 5153 or SYN5050 > 2x12 spk cab </p><p></p><p>The master volume knobs on the 5153 are for each channel, they don't affect anything that you plug into the FX return, so basically the power section of the 5153 is completely open if I understand correctly. </p><p></p><p>When using a power amp such as the SYN5050 one usually doesn't have the volume knob on 11 and most likely one doesn't run the RM4 / M4 / SYN2 master output at 11 either.</p><p>I think that's why the MR4 / M4 / SYN2 connected into the SYN5050 doesn't sound as loud as when it's connected to the FX return of the 5153.</p></blockquote><p></p>
[QUOTE="j4q0, post: 155266, member: 3288"] When using the 5153 or the SYN5050 the signal path is the same for me: Guitar > RM4 or SYN2 > 5153 or SYN5050 > 2x12 spk cab The master volume knobs on the 5153 are for each channel, they don't affect anything that you plug into the FX return, so basically the power section of the 5153 is completely open if I understand correctly. When using a power amp such as the SYN5050 one usually doesn't have the volume knob on 11 and most likely one doesn't run the RM4 / M4 / SYN2 master output at 11 either. I think that's why the MR4 / M4 / SYN2 connected into the SYN5050 doesn't sound as loud as when it's connected to the FX return of the 5153. [/QUOTE]
Verification
Post reply
Modular Amps
Low Volume
