Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
lynch box help?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="DaGuy" data-source="post: 54176" data-attributes="member: 2131"><p>I don't know how to do this going from the Randall footswitch the effects unit unless the footswitch supports MIDI. But how about the other way around i.e., have the effects unit control the channels on the Randall. That I know works. </p><p></p><p>I have an RM50LB and I can switch channels by means of an external effect unit (TC Electronic G-Major 2). That unit has a programmable relay output. This is cool since each preset knows exactly what channel to use. Now, to switch the effects on the G-Major 2, I use a MIDI pedal board.</p><p></p><p>There are some other units that do this, I know the Boss GT-8 can do this also and probably the more advanced GT-10, there's also a Behringer MIDI foot controller that does this and goes for about $150.</p></blockquote><p></p>
[QUOTE="DaGuy, post: 54176, member: 2131"] I don't know how to do this going from the Randall footswitch the effects unit unless the footswitch supports MIDI. But how about the other way around i.e., have the effects unit control the channels on the Randall. That I know works. I have an RM50LB and I can switch channels by means of an external effect unit (TC Electronic G-Major 2). That unit has a programmable relay output. This is cool since each preset knows exactly what channel to use. Now, to switch the effects on the G-Major 2, I use a MIDI pedal board. There are some other units that do this, I know the Boss GT-8 can do this also and probably the more advanced GT-10, there's also a Behringer MIDI foot controller that does this and goes for about $150. [/QUOTE]
Verification
Post reply
Modular Amps
lynch box help?
