Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Lynch Box Tube Help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Julia" data-source="post: 66176" data-attributes="member: 1784"><p>If you got the LB combo and it has the Super V12 Lynch speaker in it, that speaker is toned after the old Fane Crescendos he used to use. The Lynch speakers roll off at 4.5 kHz instead of the 5.5 kHz of the Celestions. And they lack the upper midrange spike of the Vintage 30s. </p><p></p><p>For the other channel? SL+ There is some overlap with Mr. Scary, but Mr. Scary is a little smoother than the SL+. It's perfect around 11:00 on the gain.</p><p></p><p>Real sweet as a solo set at Noon with a SG neck pickup, and it handles P90s really well.</p><p></p><p>Basically I could live with the KH1 and SL+ if I only could have two modules because you can always boost. It's hard to take away.</p></blockquote><p></p>
[QUOTE="Julia, post: 66176, member: 1784"] If you got the LB combo and it has the Super V12 Lynch speaker in it, that speaker is toned after the old Fane Crescendos he used to use. The Lynch speakers roll off at 4.5 kHz instead of the 5.5 kHz of the Celestions. And they lack the upper midrange spike of the Vintage 30s. For the other channel? SL+ There is some overlap with Mr. Scary, but Mr. Scary is a little smoother than the SL+. It's perfect around 11:00 on the gain. Real sweet as a solo set at Noon with a SG neck pickup, and it handles P90s really well. Basically I could live with the KH1 and SL+ if I only could have two modules because you can always boost. It's hard to take away. [/QUOTE]
Verification
Post reply
Modular Amps
Lynch Box Tube Help
