Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Lynch cabinet wiring?? PLEASE HELP
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="JonnyB" data-source="post: 87034" data-attributes="member: 2779"><p>Basically you can't do it, not with two speakers. You would have to wire them in series which would give you 16 ohms or parallel giving you 4 ohms. Best bet would be to wire them in series and set your amp to 16 Ohm output. The way they end up with 8 ohms in the 4 speaker cab is by wiring two lots of series connected speakers (16 ohm) in parallel.</p><p></p><p>Hope this makes sense.</p></blockquote><p></p>
[QUOTE="JonnyB, post: 87034, member: 2779"] Basically you can't do it, not with two speakers. You would have to wire them in series which would give you 16 ohms or parallel giving you 4 ohms. Best bet would be to wire them in series and set your amp to 16 Ohm output. The way they end up with 8 ohms in the 4 speaker cab is by wiring two lots of series connected speakers (16 ohm) in parallel. Hope this makes sense. [/QUOTE]
Verification
Post reply
Modular Amps
