Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
M4 arrives....finally
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Beagle1" data-source="post: 6321" data-attributes="member: 103"><p>Yes, the Rocktron effects units (Intellifex, Replifex, Xpression, etc) are designed specifically to be used directly between a preamp and poweramp. They can of course be used in an effects loop if one is available, but they work great when connected in serial between preamp and poweramp...it is in this configuration that the option to preserve the analog dry path is really useful. </p><p></p><p>There are front-panel input/output knobs and a -10/+4 switch on the Rocktron units that help you get the best level out of your preamp without overdriving the effects unit. I have one of Egnater's older IE-4 preamps (it has no FX loop) which I run into a Replifex and then an RT 2/50 poweramp...works great.</p></blockquote><p></p>
[QUOTE="Beagle1, post: 6321, member: 103"] Yes, the Rocktron effects units (Intellifex, Replifex, Xpression, etc) are designed specifically to be used directly between a preamp and poweramp. They can of course be used in an effects loop if one is available, but they work great when connected in serial between preamp and poweramp...it is in this configuration that the option to preserve the analog dry path is really useful. There are front-panel input/output knobs and a -10/+4 switch on the Rocktron units that help you get the best level out of your preamp without overdriving the effects unit. I have one of Egnater's older IE-4 preamps (it has no FX loop) which I run into a Replifex and then an RT 2/50 poweramp...works great. [/QUOTE]
Verification
Post reply
Modular Amps
