Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Rigs & Tones
Meet The New Rig (same as the old rig)
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ned" data-source="post: 158955" data-attributes="member: 2"><p>Tried adding the Rocktron Rack Interface into the mix mainly to use the mixers. Appears to be an issue with the unit as the mix 1 doesn't appear to allow signal to pass in which then causes the unit to shut down. Going to try different inputs today, there are 4 stereo pairs for each mixer.</p><p></p><p>But so far with just the pedals everything is sounding great.</p><p></p><p>Updated the GSP110 to the C63 firmware (was at C42).</p><p></p><p>Update: Even though the Rack Interface says 9VAC I decided to try it at 12VAC which solved all the problems. Probably should have noticed where I had it plugged into the Pedal Power AC before I removed the connections <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="ned, post: 158955, member: 2"] Tried adding the Rocktron Rack Interface into the mix mainly to use the mixers. Appears to be an issue with the unit as the mix 1 doesn't appear to allow signal to pass in which then causes the unit to shut down. Going to try different inputs today, there are 4 stereo pairs for each mixer. But so far with just the pedals everything is sounding great. Updated the GSP110 to the C63 firmware (was at C42). Update: Even though the Rack Interface says 9VAC I decided to try it at 12VAC which solved all the problems. Probably should have noticed where I had it plugged into the Pedal Power AC before I removed the connections :) [/QUOTE]
Verification
Post reply
Modular Amps
Rigs & Tones
