Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Midi chained of RM4 and/or M4
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="tjames" data-source="post: 142432" data-attributes="member: 3469"><p>Many midi devices only require three pins and supply power on the other two. To cut cost many cable companies only connect 3 of the 5 pins. Make sure you have the 5 pin full connect cables if needed.</p></blockquote><p></p>
[QUOTE="tjames, post: 142432, member: 3469"] Many midi devices only require three pins and supply power on the other two. To cut cost many cable companies only connect 3 of the 5 pins. Make sure you have the 5 pin full connect cables if needed. [/QUOTE]
Verification
Post reply
Modular Amps
