Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
Midi on the V2
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="RD/Rich" data-source="post: 12253" data-attributes="member: 1005"><p>To see what channel your V2 is on, press and hold the channel selct/savepreset button and hit the power switch. Check out page 13 of the manual below to see what combo of lights corispond to each channel:</p><p></p><p>http://www.randallamplifiers.com/about/warranty/manuals/T2_V2%20manual.pdf</p><p></p><p>onegunguitar is right. You will only be able to select a handful of patches. If youd need more sounds, I would suggest getting a larger controoler.</p></blockquote><p></p>
[QUOTE="RD/Rich, post: 12253, member: 1005"] To see what channel your V2 is on, press and hold the channel selct/savepreset button and hit the power switch. Check out page 13 of the manual below to see what combo of lights corispond to each channel: http://www.randallamplifiers.com/about/warranty/manuals/T2_V2%20manual.pdf onegunguitar is right. You will only be able to select a handful of patches. If youd need more sounds, I would suggest getting a larger controoler. [/QUOTE]
Verification
Post reply
Off Topic
Midi on the V2
