Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Mimicking a vintage amp
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="withmittens" data-source="post: 158142" data-attributes="member: 3096"><p>I run vintage style mods on an RM22 and RT2/50. for me I have found that running the module master all the way up or nearly and the gain at the desired sound, the amp's master can be run lower. The RM22 is better at it because it don't really have a master volume for the power section. </p><p></p><p>If I want more gain I can turn down the module volume a bit but it loses heft the lower I go. </p><p></p><p>My deluxe module has snap and growl, an added boost gets it roaring. Choose your speakers for the types of tomes you want. My Vox mod is the same way. a cleanish sound turns into a beefy roar with string attack. </p><p></p><p>Volume all the way up</p></blockquote><p></p>
[QUOTE="withmittens, post: 158142, member: 3096"] I run vintage style mods on an RM22 and RT2/50. for me I have found that running the module master all the way up or nearly and the gain at the desired sound, the amp's master can be run lower. The RM22 is better at it because it don't really have a master volume for the power section. If I want more gain I can turn down the module volume a bit but it loses heft the lower I go. My deluxe module has snap and growl, an added boost gets it roaring. Choose your speakers for the types of tomes you want. My Vox mod is the same way. a cleanish sound turns into a beefy roar with string attack. Volume all the way up [/QUOTE]
Verification
Post reply
Modular Amps
