Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Gigmods Module Mods
modding tips
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="okstrat" data-source="post: 36969" data-attributes="member: 157"><p>I can't say I've had a lot of luck with the braid either. Only problem with the pump is that it gets clogged pretty easily. The radio shack blue ones eventually won't stay together in the middle - they are plastic and screw together, eventually you'll hit the button and the top will fly across the room <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="okstrat, post: 36969, member: 157"] I can't say I've had a lot of luck with the braid either. Only problem with the pump is that it gets clogged pretty easily. The radio shack blue ones eventually won't stay together in the middle - they are plastic and screw together, eventually you'll hit the button and the top will fly across the room :) [/QUOTE]
Verification
Post reply
Modular Amps
Gigmods Module Mods
modding tips
