Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Most versatile Marshall style Synergy module?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Bulldozer1984" data-source="post: 159740" data-attributes="member: 4060"><p>Yeh the clean channel is awesome. It has to be the most versatile module for sure. </p><p></p><p>The dirty...... It totally nails GNR if you roll off a bit of bottom with a pedal on the way in. And a bit of a treble push. In fact all the 80’s tones can be had with that module by either going straight in or by manipulating the signal going in. I use a Jackson Audio Prism which is an awesome clean boost and eq in one.</p></blockquote><p></p>
[QUOTE="Bulldozer1984, post: 159740, member: 4060"] Yeh the clean channel is awesome. It has to be the most versatile module for sure. The dirty...... It totally nails GNR if you roll off a bit of bottom with a pedal on the way in. And a bit of a treble push. In fact all the 80’s tones can be had with that module by either going straight in or by manipulating the signal going in. I use a Jackson Audio Prism which is an awesome clean boost and eq in one. [/QUOTE]
Verification
Post reply
Modular Amps
