Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
MTS 2x12 cab noise
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="twistedgraffix" data-source="post: 6725" data-attributes="member: 372"><p>If the problem is that it is too tight then you could drill a hole in it. A bit permanant if it doesn't work though. </p><p> An advantage of the hole would be that you can tune the bass response a bit by adding different length tubes. There is an equation to figure out the tube diamiter and length for the frequency you want, but I don't know what it is. I have a 2x10 box that I use for practicing at home. I used a paper towel roll and kept cutting it shorter till I found a good sound. I then replaced it with PVC pipe. i put the hole on the bottom of the front panel in the center.</p></blockquote><p></p>
[QUOTE="twistedgraffix, post: 6725, member: 372"] If the problem is that it is too tight then you could drill a hole in it. A bit permanant if it doesn't work though. An advantage of the hole would be that you can tune the bass response a bit by adding different length tubes. There is an equation to figure out the tube diamiter and length for the frequency you want, but I don't know what it is. I have a 2x10 box that I use for practicing at home. I used a paper towel roll and kept cutting it shorter till I found a good sound. I then replaced it with PVC pipe. i put the hole on the bottom of the front panel in the center. [/QUOTE]
Verification
Post reply
Modular Amps
MTS 2x12 cab noise
