Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
My randall experience
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Daryl" data-source="post: 88105" data-attributes="member: 2547"><p>Well...My experience is much different. I bought an RM100 way back in '05 and other than power tube changes....NO ISSUES...</p><p>These amps do need to be set up properly and tubes biased correctly. Also the Ohm setting on the speaker outs needs to match the cab you are using. If everything is in order, it shouldn't be that outrageously defective. Although I hear that with EL34 tubes they can redplate and the board can arc to ground. That is just silly to think that a company is putting out gear that crappy. </p><p>Someone got screwed by a vendor.</p></blockquote><p></p>
[QUOTE="Daryl, post: 88105, member: 2547"] Well...My experience is much different. I bought an RM100 way back in '05 and other than power tube changes....NO ISSUES... These amps do need to be set up properly and tubes biased correctly. Also the Ohm setting on the speaker outs needs to match the cab you are using. If everything is in order, it shouldn't be that outrageously defective. Although I hear that with EL34 tubes they can redplate and the board can arc to ground. That is just silly to think that a company is putting out gear that crappy. Someone got screwed by a vendor. [/QUOTE]
Verification
Post reply
Off Topic
