Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
Nailing tones in the MTS world
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="djd100" data-source="post: 145711" data-attributes="member: 825"><p>For the recorded tone chasers out there, remember that the tube power section/cab/speaker(s)/mic @ mic-position/mic pre combinations have as much or more to do with many recorded tones than the guitar preamp.</p><p></p><p>The Two Notes Torpedo which can accurately emulate any cab(s)/speaker(s)/mic-position(s) or analog filter speaker sim(s), plus many different tube power amp sections is absolutely golden with MTS. </p><p></p><p>Not only does this eliminate SPL restrictions in that you can crush the virtual tube power amp at any SPL or DI'd, it also takes most of the weight out of a tube rig as you can run lightweight solid state power (as well as better duplicating recorded tones etc).</p><p></p><p></p><p><a href="http://www.two-notes.com/en/" target="_blank">http://www.two-notes.com/en/</a></p></blockquote><p></p>
[QUOTE="djd100, post: 145711, member: 825"] For the recorded tone chasers out there, remember that the tube power section/cab/speaker(s)/mic @ mic-position/mic pre combinations have as much or more to do with many recorded tones than the guitar preamp. The Two Notes Torpedo which can accurately emulate any cab(s)/speaker(s)/mic-position(s) or analog filter speaker sim(s), plus many different tube power amp sections is absolutely golden with MTS. Not only does this eliminate SPL restrictions in that you can crush the virtual tube power amp at any SPL or DI'd, it also takes most of the weight out of a tube rig as you can run lightweight solid state power (as well as better duplicating recorded tones etc). [url]http://www.two-notes.com/en/[/url] [/QUOTE]
Verification
Post reply
Modular Amps
Modules
