Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
DIY
Need a bit of help... Impedance switch
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="kc2eeb" data-source="post: 92022" data-attributes="member: 811"><p>Here's an old trick to remove solder quickly. You have to be working over</p><p>a table you don't mind getting solder on. Works only with parts that can take a gentle tap.</p><p>Heat the solder joint until it is liquid and drop or tap the switch on the table</p><p>while the solder is still molten. A lot of the solder will splash out.</p><p>Then clean up with the de-soldering braid.</p></blockquote><p></p>
[QUOTE="kc2eeb, post: 92022, member: 811"] Here's an old trick to remove solder quickly. You have to be working over a table you don't mind getting solder on. Works only with parts that can take a gentle tap. Heat the solder joint until it is liquid and drop or tap the switch on the table while the solder is still molten. A lot of the solder will splash out. Then clean up with the de-soldering braid. [/QUOTE]
Verification
Post reply
Modular Amps
DIY
