Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
no sound output from t2
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="gweb" data-source="post: 44496" data-attributes="member: 507"><p>There's a fuse where the power cord plugs in. Should be square and has different voltages listed. Just pop it out, but make sure you put it back in the same way...if you turn it you will have the incorrect voltage setting. I had one of these go on me once and it was a simple fix, got the fuse at Radio Shack. Hope that helps.</p><p></p><p>Greg</p></blockquote><p></p>
[QUOTE="gweb, post: 44496, member: 507"] There's a fuse where the power cord plugs in. Should be square and has different voltages listed. Just pop it out, but make sure you put it back in the same way...if you turn it you will have the incorrect voltage setting. I had one of these go on me once and it was a simple fix, got the fuse at Radio Shack. Hope that helps. Greg [/QUOTE]
Verification
Post reply
Off Topic
