Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
[No title]
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="LuxxtoneBoy" data-source="post: 157987" data-attributes="member: 3841"><p>Hey brother,</p><p></p><p>Can you explain how to connect 2 Syn2’s into a SYN 50/50? </p><p></p><p>I have a Synergy 2x12 cab and would like to use it in stereo (I pressume this is done by connecting the Syn 50/50 into each of the 16ohm inputs that are in the back of the cab. What outputs should I use from the Syn 50/50 to connect to the cabs and what impedance setting should I select on the Syn 50/50?</p><p></p><p>I reveived todavis my Fractal FX8, but maybe I should start with hooking up the poweramp and preamps, then I can start asking questions on how to use the 4 cable method to add the FX8.</p><p></p><p>Thanks in advance for your help.</p></blockquote><p></p>
[QUOTE="LuxxtoneBoy, post: 157987, member: 3841"] Hey brother, Can you explain how to connect 2 Syn2’s into a SYN 50/50? I have a Synergy 2x12 cab and would like to use it in stereo (I pressume this is done by connecting the Syn 50/50 into each of the 16ohm inputs that are in the back of the cab. What outputs should I use from the Syn 50/50 to connect to the cabs and what impedance setting should I select on the Syn 50/50? I reveived todavis my Fractal FX8, but maybe I should start with hooking up the poweramp and preamps, then I can start asking questions on how to use the 4 cable method to add the FX8. Thanks in advance for your help. [/QUOTE]
Verification
Post reply
Modular Amps
[No title]
