Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
noob question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BigBrewtus" data-source="post: 91355" data-attributes="member: 2516"><p>I believe if you kept it on stereo and only plugged into one side it would be okay. It just means you are running one side of the cab at 8ohms. Also at 50 watts. </p><p>As far as ohms go as long as you cab matches or is higher than your amp ohms you are fine. If your cab is lower than the amp you risk damage to your amp.</p></blockquote><p></p>
[QUOTE="BigBrewtus, post: 91355, member: 2516"] I believe if you kept it on stereo and only plugged into one side it would be okay. It just means you are running one side of the cab at 8ohms. Also at 50 watts. As far as ohms go as long as you cab matches or is higher than your amp ohms you are fine. If your cab is lower than the amp you risk damage to your amp. [/QUOTE]
Verification
Post reply
Off Topic
noob question
