Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Rigs & Tones
Parallel modules, hack MTS!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="djd100" data-source="post: 80303" data-attributes="member: 825"><p>The modules could be hacked to provide "A" or "B" in a RM4.</p><p></p><p>Adding Eggie channel switching from an external non-MIDI pedal would also work, though not via MIDI, rather you'd need to hack it to control the internal CV (assuming the GCX can switch non-MIDI amp channels like my X-15 does). Adding a switch would work as well.</p><p></p><p>The Eggie channel/MTS module switching duties are ultimately controlled by CV (CV controlled by MIDI stock), so controlling the CV can accomplish whatever you need.</p><p></p><p>Again, be aware that you'll need a mixing matrix if mixing, and a old-school way to control the CV like a mechanical switch (foot, toggle, within a MIDI pedal like the X-15 etc). Also, again, the phase flips with added tube stages so some module combinations will not mix well in mono.</p></blockquote><p></p>
[QUOTE="djd100, post: 80303, member: 825"] The modules could be hacked to provide "A" or "B" in a RM4. Adding Eggie channel switching from an external non-MIDI pedal would also work, though not via MIDI, rather you'd need to hack it to control the internal CV (assuming the GCX can switch non-MIDI amp channels like my X-15 does). Adding a switch would work as well. The Eggie channel/MTS module switching duties are ultimately controlled by CV (CV controlled by MIDI stock), so controlling the CV can accomplish whatever you need. Again, be aware that you'll need a mixing matrix if mixing, and a old-school way to control the CV like a mechanical switch (foot, toggle, within a MIDI pedal like the X-15 etc). Also, again, the phase flips with added tube stages so some module combinations will not mix well in mono. [/QUOTE]
Verification
Post reply
Modular Amps
Rigs & Tones
