Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
Please help, is this normal, T2
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="gweb" data-source="post: 43307" data-attributes="member: 507"><p>I've owned two of them. Those amps have way more tight gain and low end than the Mesa Rectifier I had and any of they Marshall's I ever owned or played through. The red channel will give you trouble if you have lower quality pickups though. That was my first thought when you mentioned uncontrollable squealing. I preferred the green channel for rhythm and used the red channel for leads.</p><p></p><p>I usually had my settings like this:</p><p></p><p>Gain 3 o'clock</p><p>Bass full up</p><p>Mid 1 o'clock</p><p>Sweep 11 o'clock</p><p>Treble noon</p><p>Density 2 o'clock</p><p>Presence between 0 and noon depending on the room.</p><p></p><p>I had a gate and wah in front and a bunch of stuff in the loop. Loop levels both around noon. If you have the loop volumes full up it sounds like crap. There is a certain amount of tweeking with loop levels to get a good balance but both T2's that I owned were plug and play brutal right from the start. I only got rid of them to move up to the MTS system, but I still miss those amps.</p><p></p><p>Greg</p></blockquote><p></p>
[QUOTE="gweb, post: 43307, member: 507"] I've owned two of them. Those amps have way more tight gain and low end than the Mesa Rectifier I had and any of they Marshall's I ever owned or played through. The red channel will give you trouble if you have lower quality pickups though. That was my first thought when you mentioned uncontrollable squealing. I preferred the green channel for rhythm and used the red channel for leads. I usually had my settings like this: Gain 3 o'clock Bass full up Mid 1 o'clock Sweep 11 o'clock Treble noon Density 2 o'clock Presence between 0 and noon depending on the room. I had a gate and wah in front and a bunch of stuff in the loop. Loop levels both around noon. If you have the loop volumes full up it sounds like crap. There is a certain amount of tweeking with loop levels to get a good balance but both T2's that I owned were plug and play brutal right from the start. I only got rid of them to move up to the MTS system, but I still miss those amps. Greg [/QUOTE]
Verification
Post reply
Off Topic
