Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
Please help T2 or V2
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="terminator2" data-source="post: 14512" data-attributes="member: 1074"><p>I have the T2, and have not played the V2. If you need lots of versatility of equalization you might want to go with the V2. But I love the T2 because every channel runs through the tube preamp. (on the V2 the clean and 1st overdrive channel are both solid state) The T2 is more versatile than people think. The only limitation is the lack of separate EQ's, which I don't really need. The amp might not sound that great with that beringer cab though. These amps have like 10x more bass than any other. Its crazy. You might also want to pick up a BBE sonic maximizer, because the T2 sounds a little mudddy with out it. The lows overpower the highs and mids without the BBE. With the BBE and a good 4x12 its quite an experience. These amps absolutely destroy any mesa boogie, crate, carvin, newer marshalls, peaveys (although I like the JSX alot).</p></blockquote><p></p>
[QUOTE="terminator2, post: 14512, member: 1074"] I have the T2, and have not played the V2. If you need lots of versatility of equalization you might want to go with the V2. But I love the T2 because every channel runs through the tube preamp. (on the V2 the clean and 1st overdrive channel are both solid state) The T2 is more versatile than people think. The only limitation is the lack of separate EQ's, which I don't really need. The amp might not sound that great with that beringer cab though. These amps have like 10x more bass than any other. Its crazy. You might also want to pick up a BBE sonic maximizer, because the T2 sounds a little mudddy with out it. The lows overpower the highs and mids without the BBE. With the BBE and a good 4x12 its quite an experience. These amps absolutely destroy any mesa boogie, crate, carvin, newer marshalls, peaveys (although I like the JSX alot). [/QUOTE]
Verification
Post reply
Off Topic
