Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Please Help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="EdgeOvThorns" data-source="post: 2739" data-attributes="member: 223"><p>Trendkill thank you for the detailed breakdown. Ive decided to give it a shot</p><p> I bought the multimeter and im going to try to install the other two power tubes. I also plan on ordering all new tubes for the amp and could really use a link to a good website for this. Im still not sure if i want el34's or 6l6's for the power section but I will definitely try the 12ax7's for the pre-amp tubes. </p><p></p><p>Now I need to see if anyone on here wants a clean channel module so that I can get myself a Blackface and ill probably just buy the XTC. I do plan on using a boost and possibly an eq for leads so thanks for that butchieT, you saved me the trial and error and worrying about a seperate channel for my leads and I may just keep the ultra module in after all.</p></blockquote><p></p>
[QUOTE="EdgeOvThorns, post: 2739, member: 223"] Trendkill thank you for the detailed breakdown. Ive decided to give it a shot I bought the multimeter and im going to try to install the other two power tubes. I also plan on ordering all new tubes for the amp and could really use a link to a good website for this. Im still not sure if i want el34's or 6l6's for the power section but I will definitely try the 12ax7's for the pre-amp tubes. Now I need to see if anyone on here wants a clean channel module so that I can get myself a Blackface and ill probably just buy the XTC. I do plan on using a boost and possibly an eq for leads so thanks for that butchieT, you saved me the trial and error and worrying about a seperate channel for my leads and I may just keep the ultra module in after all. [/QUOTE]
Verification
Post reply
Modular Amps
Please Help
