Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
Plexi vs Brown
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="guitarguy510" data-source="post: 4229" data-attributes="member: 44"><p>Yeah I was going to say try adding an EQ and/or an OD pedal out in front of the Plexi and see if that helps. Might be all you need! If you push the input a little hotter you can get more gain but still keep the flavor of the plexi. Good luck man! <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" /></p></blockquote><p></p>
[QUOTE="guitarguy510, post: 4229, member: 44"] Yeah I was going to say try adding an EQ and/or an OD pedal out in front of the Plexi and see if that helps. Might be all you need! If you push the input a little hotter you can get more gain but still keep the flavor of the plexi. Good luck man! :D [/QUOTE]
Verification
Post reply
Modular Amps
Modules
Plexi vs Brown
