Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Potential Rig - Thoughts?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="///MK" data-source="post: 44910" data-attributes="member: 1744"><p>I have some similar gear and I think it is important to consider what you intended use for all this great gear is. If you are a gigging musician and you are not in an act with a big dedicated road crew I would strongly suggest not going with the 2 heads + rack space all in once case. It will be too heavy to move and you will curse the thing every time you have to go through I flight of stair(this led me to purchase the Axe-fx as a dedicated "b" rig). A couple of smaller cases is a lot easier to move around. Now if you are going to use this in a home studio type environment then a big all in one case is fine although I would probably rather just build one with nice lumbar stained etc.</p></blockquote><p></p>
[QUOTE="///MK, post: 44910, member: 1744"] I have some similar gear and I think it is important to consider what you intended use for all this great gear is. If you are a gigging musician and you are not in an act with a big dedicated road crew I would strongly suggest not going with the 2 heads + rack space all in once case. It will be too heavy to move and you will curse the thing every time you have to go through I flight of stair(this led me to purchase the Axe-fx as a dedicated "b" rig). A couple of smaller cases is a lot easier to move around. Now if you are going to use this in a home studio type environment then a big all in one case is fine although I would probably rather just build one with nice lumbar stained etc. [/QUOTE]
Verification
Post reply
Modular Amps
