Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Jaded Faith Mods
Quickmod GT Users
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="warlok" data-source="post: 128709" data-attributes="member: 2626"><p>From what I'm understanding of the problem, and the fix to the amp slot with washers, this is a valid question. Does a "normal" module fit correctly after the washers are installed?</p><p></p><p>If it is only that the curcuit board is 1/32" short, I could make some new module plates to space the few short boards back 1/32" with just some washers between the plates and the pots. Hell, pretty much anyone with a sheet metal brake and a drill press could.. No amp/washer mod needed and no chance of making a different module not fit.. (if that is also an issue..)</p></blockquote><p></p>
[QUOTE="warlok, post: 128709, member: 2626"] From what I'm understanding of the problem, and the fix to the amp slot with washers, this is a valid question. Does a "normal" module fit correctly after the washers are installed? If it is only that the curcuit board is 1/32" short, I could make some new module plates to space the few short boards back 1/32" with just some washers between the plates and the pots. Hell, pretty much anyone with a sheet metal brake and a drill press could.. No amp/washer mod needed and no chance of making a different module not fit.. (if that is also an issue..) [/QUOTE]
Verification
Post reply
Modular Amps
Jaded Faith Mods
Quickmod GT Users
