Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Randall Rig Reform
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Tubes In a Hat" data-source="post: 71221" data-attributes="member: 2517"><p>I'm planning on using a rack with a G-Force and an audio switcher either way, so using a rack mounted preamp and power amp would just be more compact than it would be lighter I suppose.</p><p></p><p>The KH1 seems like the way to go for higher headroom cleans. I have a Timmy overdrive pedal... not exactly the same type of thing as the Zen Drive, but... ball park.</p><p></p><p>I emailed Pete at gigmods and for a bit over $500 I could get the "pro" mods for my current modules. He also said he could turn my SL+ into a Mk I type of thing.</p><p></p><p>If I could get a high-headroom warm clean channel, a Mk I esque sounding channel, and a Recto sounding channel that was less buzzy and tighter on the low end, I think I'd be quite contented sticking with the RM100 head... provided it will be dependable and not blow fuses in the middle of a gig.</p><p></p><p>It turns out I'm more of a Mesa guy than a Marshall guy... but if I'm not mistaken, the Recto circuit shares quite a few similarities with the SLO circuit...</p></blockquote><p></p>
[QUOTE="Tubes In a Hat, post: 71221, member: 2517"] I'm planning on using a rack with a G-Force and an audio switcher either way, so using a rack mounted preamp and power amp would just be more compact than it would be lighter I suppose. The KH1 seems like the way to go for higher headroom cleans. I have a Timmy overdrive pedal... not exactly the same type of thing as the Zen Drive, but... ball park. I emailed Pete at gigmods and for a bit over $500 I could get the "pro" mods for my current modules. He also said he could turn my SL+ into a Mk I type of thing. If I could get a high-headroom warm clean channel, a Mk I esque sounding channel, and a Recto sounding channel that was less buzzy and tighter on the low end, I think I'd be quite contented sticking with the RM100 head... provided it will be dependable and not blow fuses in the middle of a gig. It turns out I'm more of a Mesa guy than a Marshall guy... but if I'm not mistaken, the Recto circuit shares quite a few similarities with the SLO circuit... [/QUOTE]
Verification
Post reply
Modular Amps
Randall Rig Reform
