Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
Randall RM100 Problems
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="evhwolfie" data-source="post: 4766" data-attributes="member: 185"><p>Probally just a bad tube, ive found out that the little red light dose not always come on when a tube is bad, you should never go higher than 38mV or 39mV with 6l6s. Also I would check your fuses if I were you. It dosent matter if the tubes are matched or not, you just always bias each tube to be the same when you put it in, all the tubes should read the same mV when your done.</p></blockquote><p></p>
[QUOTE="evhwolfie, post: 4766, member: 185"] Probally just a bad tube, ive found out that the little red light dose not always come on when a tube is bad, you should never go higher than 38mV or 39mV with 6l6s. Also I would check your fuses if I were you. It dosent matter if the tubes are matched or not, you just always bias each tube to be the same when you put it in, all the tubes should read the same mV when your done. [/QUOTE]
Verification
Post reply
Off Topic
