Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
Randall RT100h
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ctgblue" data-source="post: 98793" data-attributes="member: 2887"><p>the 6505 IS a one trick pony, which is why I have a 3120.</p><p>3 channels, 2 of them with the same amount of gain, 3 sep EQ sections, and cost less</p><p></p><p>Dime = 10, cranking the amp master volume all the way then lowering volume with an attenuator. Kills power tubes and can wear out the entire system</p><p></p><p>Saturation, the sound you are after, high gain but smooth and runs together, not "grainy" sounding</p><p></p><p>Sucks tone, attenuators can drain the highs and mids from the preamp tones when lowering volume, leaving a 'muffled sound'</p><p>Better ones have adjustments to add the tones back in</p><p></p><p> my 3120 has so much gain I can run the master under "1" and it still sounds sick and nasty (good terms)</p></blockquote><p></p>
[QUOTE="ctgblue, post: 98793, member: 2887"] the 6505 IS a one trick pony, which is why I have a 3120. 3 channels, 2 of them with the same amount of gain, 3 sep EQ sections, and cost less Dime = 10, cranking the amp master volume all the way then lowering volume with an attenuator. Kills power tubes and can wear out the entire system Saturation, the sound you are after, high gain but smooth and runs together, not "grainy" sounding Sucks tone, attenuators can drain the highs and mids from the preamp tones when lowering volume, leaving a 'muffled sound' Better ones have adjustments to add the tones back in my 3120 has so much gain I can run the master under "1" and it still sounds sick and nasty (good terms) [/QUOTE]
Verification
Post reply
Off Topic
Randall RT100h
