Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
If you have bought, sold or gained information from our Classifieds, please donate to Synergy/MTS Forum and give back.
You can
become a Supporting Member
which comes with a decal or just
click here to donate
General Forum Information
Classifieds
Randall RT2/50 in Sydney Austalia for $850AUD
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Bradle" data-source="post: 148319" data-attributes="member: 3545"><p>So I was playing thru my Mr Scary the other day when it started to drop in volume, then suddenly pick back up and just generally sound fizzy (other modules sounded fine). Switched the amp off opened up the mr scary and R38 is burnt out and C20 (one of the top right hand electrolytic caps) next to it has a tiny bit of yellowish oil like goop on it. Is C20 leaking causing R38 to cook or is there likely another issue?</p><p></p><p>Cheers Brad</p><p></p><p>Also I'm saving my pennies at the moment for my first modded module, not too sure what I want, something hi gain a little Recto-ish any suggestions? [/img]</p></blockquote><p></p>
[QUOTE="Bradle, post: 148319, member: 3545"] So I was playing thru my Mr Scary the other day when it started to drop in volume, then suddenly pick back up and just generally sound fizzy (other modules sounded fine). Switched the amp off opened up the mr scary and R38 is burnt out and C20 (one of the top right hand electrolytic caps) next to it has a tiny bit of yellowish oil like goop on it. Is C20 leaking causing R38 to cook or is there likely another issue? Cheers Brad Also I'm saving my pennies at the moment for my first modded module, not too sure what I want, something hi gain a little Recto-ish any suggestions? [/img] [/QUOTE]
Verification
Post reply
Classifieds
