Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
RG50TC in need of resuscitation
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="AndyM" data-source="post: 106331" data-attributes="member: 3008"><p>The amp I traded in for my Randall did this twice.</p><p></p><p>The initial problem was simply carbon buildup on the circuit board, which caused something to short out. The first time it happened, I tinkered with it for about a week and just ended up doing more damage than good. Ended up having to replace the cheap connector I fried.</p><p></p><p>The second time it happened, I got desperate and scrubbed all the solder connections with a toothbrush (the board DID look pretty dirty). Turned it on, and everything worked fine. </p><p></p><p>I'm not at all sure about what's wrong with yours, this is just a guess.</p><p></p><p>Were the tubes still lighting up right after this happened? I know you said nothing's lighting up now, but I'm wondering if anything might have gotten damaged between the time it stopped working and now.</p></blockquote><p></p>
[QUOTE="AndyM, post: 106331, member: 3008"] The amp I traded in for my Randall did this twice. The initial problem was simply carbon buildup on the circuit board, which caused something to short out. The first time it happened, I tinkered with it for about a week and just ended up doing more damage than good. Ended up having to replace the cheap connector I fried. The second time it happened, I got desperate and scrubbed all the solder connections with a toothbrush (the board DID look pretty dirty). Turned it on, and everything worked fine. I'm not at all sure about what's wrong with yours, this is just a guess. Were the tubes still lighting up right after this happened? I know you said nothing's lighting up now, but I'm wondering if anything might have gotten damaged between the time it stopped working and now. [/QUOTE]
Verification
Post reply
Off Topic
