Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
RH300G3 plus bass problem?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="billymagnum" data-source="post: 63841" data-attributes="member: 2344"><p>I noticed when playing with the bass eq on the dirty channels to over 5 the volume cuts to a lower level and then kind of just fades back to normal. Is this an amp problem or could I need to check the wires inside my cab? The cab is an older Laney from the 80's but Im not sure if this is a known issue with G3 plus head? Help?</p></blockquote><p></p>
[QUOTE="billymagnum, post: 63841, member: 2344"] I noticed when playing with the bass eq on the dirty channels to over 5 the volume cuts to a lower level and then kind of just fades back to normal. Is this an amp problem or could I need to check the wires inside my cab? The cab is an older Laney from the 80's but Im not sure if this is a known issue with G3 plus head? Help? [/QUOTE]
Verification
Post reply
Off Topic
