Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Rigs & Tones
Rig help with Pod HD500, RM4 and poweramp
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="JonnyB" data-source="post: 88861" data-attributes="member: 2779"><p>I run an HD500 / Lynch Box configuration live which is pretty similar. Please make sure you have the HD500 set to line level on the effects loop. It's a pretty powerful combination but I have 3 modules so don't really use the amp modelling stuff much. I do use some of the stombox models before and after the pre-amp though and this works well.</p><p></p><p>It's connected like this -</p><p></p><p>Guitar - HD500 Guitar Input -></p><p>HD500 Clean Boost and Tube Screamer models -></p><p>HD500 External Loop Out - > Lynch Box Input</p><p>Lynch Box Pre Amp (3 Modules switched from HD500 via MIDI)</p><p>Lynch Box Serial Loop Out -> HD500 External Loop In</p><p>HD500 Noise Gate</p><p>HD500 Delay/Modulation</p><p>HD500 Main Out (Mono) -> Lynch Box Serial Loop In</p><p></p><p>If I want to bypass the LB modules I simply set a patch where the External Loop is set to off. Works a treat.</p><p></p><p>I have to say the HD500 is the way to go (as opposed to the 300 and 400) as it has all the M13 effects and plenty of switches to control both the internal effects and the Lynch Box.</p><p></p><p>Hope this helped.</p><p></p><p>Cheers!</p></blockquote><p></p>
[QUOTE="JonnyB, post: 88861, member: 2779"] I run an HD500 / Lynch Box configuration live which is pretty similar. Please make sure you have the HD500 set to line level on the effects loop. It's a pretty powerful combination but I have 3 modules so don't really use the amp modelling stuff much. I do use some of the stombox models before and after the pre-amp though and this works well. It's connected like this - Guitar - HD500 Guitar Input -> HD500 Clean Boost and Tube Screamer models -> HD500 External Loop Out - > Lynch Box Input Lynch Box Pre Amp (3 Modules switched from HD500 via MIDI) Lynch Box Serial Loop Out -> HD500 External Loop In HD500 Noise Gate HD500 Delay/Modulation HD500 Main Out (Mono) -> Lynch Box Serial Loop In If I want to bypass the LB modules I simply set a patch where the External Loop is set to off. Works a treat. I have to say the HD500 is the way to go (as opposed to the 300 and 400) as it has all the M13 effects and plenty of switches to control both the internal effects and the Lynch Box. Hope this helped. Cheers! [/QUOTE]
Verification
Post reply
Modular Amps
Rigs & Tones
