Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
RM-20/22 Silent Mode?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Jaded Faith" data-source="post: 131483" data-attributes="member: 1068"><p>I seem to recall this being addressed to an extent in the manual and rarely ever use my RM22, never for recording. From what I recall and based on the schematics:</p><p></p><p>- I am certain it can be used for silent recording and has an internal load for this.</p><p></p><p>- The FX loop is between the pre and power sections, so it should be active in silent recording. The silent recording out taps it's signal off of the speaker out post power amp.</p><p></p><p>- The non-compensated out is always between the pre and power sections (same as an FX loop), so this too should be active.</p><p></p><p>Hope that helps,</p><p>Rob</p></blockquote><p></p>
[QUOTE="Jaded Faith, post: 131483, member: 1068"] I seem to recall this being addressed to an extent in the manual and rarely ever use my RM22, never for recording. From what I recall and based on the schematics: - I am certain it can be used for silent recording and has an internal load for this. - The FX loop is between the pre and power sections, so it should be active in silent recording. The silent recording out taps it's signal off of the speaker out post power amp. - The non-compensated out is always between the pre and power sections (same as an FX loop), so this too should be active. Hope that helps, Rob [/QUOTE]
Verification
Post reply
Modular Amps
Modules
