Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM 80 crackle problem
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="CrunchBunch" data-source="post: 150899" data-attributes="member: 3591"><p>I've got two identical RM80 combos (they're basically an RM50 with 6550 power tubes and 2 x Celestion G12T-75 speakers arranged diagonally in the case).</p><p></p><p>On one of them, when using high gain modules I get a crackle in the background which becomes audible when a struck power chord decays.</p><p></p><p>It's almost as if something is loose inside and is causing the crackle. It is not an issue at lower volumes.</p><p></p><p>Having two means I've been able to test all of the usual suspects, like microphonic tubes, bad modules etc. Swapping everything back and forth has not helped. Running the head outside the combo and probing around inside with an insulated tool has also not revealed any loose connection etc.</p><p></p><p>Does anyone have any ideas? I've even played it removed from the case in the pitch dark to see if there was any arcing, but could detect nothing of the sort.</p></blockquote><p></p>
[QUOTE="CrunchBunch, post: 150899, member: 3591"] I've got two identical RM80 combos (they're basically an RM50 with 6550 power tubes and 2 x Celestion G12T-75 speakers arranged diagonally in the case). On one of them, when using high gain modules I get a crackle in the background which becomes audible when a struck power chord decays. It's almost as if something is loose inside and is causing the crackle. It is not an issue at lower volumes. Having two means I've been able to test all of the usual suspects, like microphonic tubes, bad modules etc. Swapping everything back and forth has not helped. Running the head outside the combo and probing around inside with an insulated tool has also not revealed any loose connection etc. Does anyone have any ideas? I've even played it removed from the case in the pitch dark to see if there was any arcing, but could detect nothing of the sort. [/QUOTE]
Verification
Post reply
Modular Amps
